Thread: Flash Gas
12-12-2007, 02:58 AM #1
Flash Gas
How do I calculate the mass flow of vapor being produced by flashing NH3 from a HPR to a Flash Tank?
I know I need 1482 lbs/hr of 25°F liquid to send to the LPR so I need 1482 lbs/hr of 90°F liquid + flash gas to send to the Economizer from the HPR. The economizer suction will see 767 lbs/hr from the low temp. evaps + this flash gas. I'd like to be able to calculate it by hand.
Not worried about defrosting at this point.
Steve
20-12-2007, 01:31 AM #2
Re: Flash Gas
By my calculations... 228.4 lbs/hr.
Always ask yourself, how much energy does it take to cool 1482 lbs/hr of liquid ammonia from 90 to 25?
Now that you know the ammount of energy you need. Then ask yourself, how much mass of ammonia would i need that would absorb this ammount of energy from a phase change from 90 degrees F liquid to 25 degrees F vapor.
Simple problem if you break it down.
flash gas
By bandit in forum FundamentalsReplies: 13Last Post: 19-09-2010, 06:21 PM -
shining fault codes
By al in forum Air ConditioningReplies: 3Last Post: 17-07-2010, 08:34 AM -
Effect of Hot Gas and Flash gas on Evaporators
By NH3LVR in forum Technical SpeculationsReplies: 10Last Post: 14-08-2007, 05:58 AM -
Evaporator Flash over
By Chef in forum FundamentalsReplies: 8Last Post: 25-06-2007, 11:02 AM -
what's the difference between the dry and flash type economizer?
By jackcn in forum FundamentalsReplies: 1Last Post: 16-12-2003, 12:33 AM
