    Mar 2006
    Lancashire
    1,859
    28
    York Controller Password
    Just had a call out for tomorrow to a restaurant that has a Lennox unit with a York controller inside the HVAC panel. The guy that went to it this evening said that he couldn't get into the controller as it was asking for a password, he was trying to determine the setpoints. Before i go does anyone know what the standard password is for York controllers?
    Marc
    70
    4,703
    47
    Thumbs up Re: York Controller Password
    marc
    I did not realise that Lennox used York Controllers.
    What type of controller is it?
    With the basic rooftop / Unitary controllers :-
    TYPES- DSL 600, 610 AND 700
    In Cool Mode.
    Select the temperature you want your equipment to maintain while in cooling mode by momentarily pressing the up or down button. The temperature setpoint is displayed for 5 seconds after releasing the button.
    In Heat Mode .
    Select the temperature you want your equipment to maintain while in heating mode by pressing and holding the up or down button. The temp setpoint is displayed for 5 secs after releasing the button.
    If I can help further let me know once you know what type of controller it is.
    Cheers Grizzly
    Mar 2006
    Lancashire
    1,859
    28
    Hi Grizzly, i didn't think Lennox used York controllers either...they normally have their own little controller but hes adamant that its York and until i get there i wont know. Thanks for the info though i'll take it with me so i'm prepared.
    Marc
    5,667
    The default codes are
    Level 1 = 1234
    Level 2 = 4321
    Mar 2006
    Lancashire
    1,859
    28
    Thanks for the codes frank they will come in handy i'm sure. Got to the site on Sunday, didn't need a code to access the setpoints as the other guy mentioned. It was a Lennox unit and it was controlled through a York controller as well as other AHU's. The coil was freezing up due to the unit being short of refrigerant causing the unit to trip out due to no airflow...
    Marc
    70
    4,703
    47
    Marc.
    Thanks for the update, allways nice to find out how someone got on.
    Pure luck to of guessed the correct access route. As we said before strange setup.
    But all's well that ends well!
    Grizzly (the other guy!)
    Mar 2006
    Lancashire
    1,859
    28
    Just to let you know the controller did need a password to change certain settings, if anyone is looking for one try 5555.
    Marc
  1. Daikin Hard wired controller
    By marc5180 in forum Air Conditioning
    Last Post: 10-11-2007, 06:43 PM
  2. H0 on Mitsubishi Controller
    By Freecool in forum Air Conditioning
    Last Post: 29-09-2007, 07:24 PM
  3. Help with new electronic refrigerator controller !
    By EngiGal in forum New Technologies
    Last Post: 08-04-2006, 07:39 PM
  4. Controller wiring
    By Mickvee in forum Air Conditioning
    Last Post: 30-12-2005, 02:04 AM
  5. Fan Controller
    By Abe in forum Trouble Shooting
    Last Post: 12-01-2002, 02:21 AM
