Results 1 to 15 of 15
Thread: Thermoking Thermo Guard IV
Threaded View
05-12-2007, 05:08 PM #11
Re: Thermoking Thermo Guard IV
Sounds like you performed cold start or flashload, when doing this this causes the micro prom to revert to a default setting, which is the instructions that are preprogrammed on the chip, you will have to program the unit and calibrate the sensors possibly shunt calibration, then whil you are in super guarded access you may also push the code key to see the alarm 74 then press clear.
Depending on models you may have to program the following for example:
electric stby
ETV or no etv
screw or no screw comp
spectrum no spectum
yanmar engine or isuzu engine
internal logger no internal logger which is in a embedded screen in super guarde access
programmed optiset or default opti again embedded acces
there are many configs and programmings specific to unit model .
Oh crap this post is older than sh*t. you probably know all of this now.
Regards R-T
thermoking container manuals
By jamcool in forum TransportReplies: 68Last Post: 18-11-2009, 07:53 PM -
thermo acoustic refrigerator: problem with stack heating
By jackal in forum Technical DiscussionsReplies: 6Last Post: 04-09-2006, 05:03 PM -
Thermo King v? 00 MAX Tc Wiring Diagram
By Chris2005 in forum TransportReplies: 3Last Post: 01-02-2006, 08:01 AM -
I want to find detailed files about ALCO zz thermo expansion valve
By brightfu1 in forum FundamentalsReplies: 2Last Post: 07-09-2005, 03:07 PM -
Thermo Fluid Plate Exchangers
By J.D in forum IndustrialReplies: 3Last Post: 09-07-2002, 03:46 PM
