    Aug 2007
    racine, wi
    68
    135
    recovery tank question
    this is probably a stupid question,, but what the heck,,,,
    on a standard yellow and gray recovery tank there is a vapor port and a liquid port. if i take liquid out of a cooler and put it in the recovery tank,,, how do i get the liquid back into the cooler?
    in other words,,, do i need to invert the bottle, or is the liquid line attached to a tube at the bottom of the tank?
    thanks,
    mike
    Re: recovery tank question
    In a two tap bottle the liquid tap is connected to the bottom of the tank with a dip tube.
    If all else fails, use the vapour tap and invert the tank.
    Aug 2007
    racine, wi
    68
    135
    sheesh,, i never thought of that,,, invert the bottle and use the vapor line. thanks brian
    Jan 2003
    East Anglia
    1,160
    Whilst on the subject of recovering gas, does anyone else put a drier in the line to filter any contaminates out or is it just me being anal
    Raymond
    Nov 2006
    708
    Buy a Polar Pump cause they have a servicable strainier inside then you don`t need an external one after all they are only used to prevent solid foriegn matter entering the compressor and causing damage
    Feb 2001
    Doncaster, England
    199
    Raymond,
    it is good practice to put a filter/dryer in the line as you are recovering.
    Some manufacturers of recovery units insist on it.
    Tony
    Aug 2007
    Adelaide Australia
    70
    562
    Hi Raymond
    We use a drier on the suction to our recovery units. This helps to protect the recovery compressor and is usually changed each time they are used, cheap insurance.
    Some makers also recommend a small amount of oil in the suction as well, helps to lubricate the bearings.
    Paul
    Aug 2007
    racine, wi
    68
    135
    i have a drier for that purpose,, but i havent worked on a system that i would doubt the cleanliness of the refrigerant. i have this picture in my head of sucking some kinda gray sludge out of some old cooler and pulling it through my new machine.
  1. surge tank on racks
    By frozen ocean in forum Supermarket Refrigeration
    Last Post: 25-08-2009, 03:22 PM
  2. Need Help with cold water tank design
    By ac_sheldon in forum Industrial
    Last Post: 21-11-2008, 11:24 PM
  3. vacuum in a recovery cylinder?
    By flyboy3b in forum New to RE
    Last Post: 24-09-2007, 09:38 PM
  4. natural Stratification tank
    By Camille in forum Industrial
    Last Post: 03-05-2007, 01:48 PM
  5. Urgent, Kirchoff question
    By Peter_1 in forum Fundamentals
    Last Post: 20-01-2004, 03:12 PM
