Results 1 to 16 of 16
    Apr 2007
    42
    29
    415v crankcase heaters
    Hi. Does anybody know of where I can get 415v crankcase heater tapes from.They need to be 1000mm long and 70w. I've tried RPW,Climate center and Google with no luck.
    Feb 2007
    2,473
    Re: 415v crankcase heaters
    I had this problem years ago,
    In the end I ended up fitting a transformer and using a standard 240V heater.
    Apr 2007
    42
    29
    Might end up having to do that. Thanks Viking
    I have to ask - why the transformer ?
    If the unit is three phase 415v why not tap off one phase to get the 230v?
    Or am I missing some 'correct electrical procedure'?
    Feb 2007
    2,473
    Well, I assumed that as the question were asked, the unit in question lacks the Neutral (and it is really bad practice to connect it to earth)....
    But I might be wrong, it have happened once in the past.
    Apr 2007
    42
    29
    yes the unit does not have a neutral. its just 3ph + earth.
    Aug 2007
    Adelaide Australia
    70
    562
    Viking is right it is not good practice to use the earth as the neutral, reason being the earth could be defective and if so you will liven up any metal part of the installation. Earth connections are either to a water pipe (old houses) or a metal stake in the ground.
    A 415V transformed is the probably the best way of using a 240V heater.
    Mar 2005
    58
    110
    If you're looking for a belt type crankcase heater to go around a hermetic compressor, you could try this one:
    Danfoss Maneurop has a 400V 75W crankcase heater for the MTZ-4cylinder compressors. The perimeter of this compressor is about 97 cm. The code for it is 7773014.
    You could check with your local Danfoss Maneurop dealer (D&W ?)
    Best regards
    Colombo
    72
    Quote Originally Posted by PaulZ View Post
    I also face a similar problem. Finally I used 415 transformer with neutral . Problem solved.
    Feb 2007
    2,473
    Viking is right
    There was a doubt?
    5,667
    Who mentioned that the earth was going to be used as a neutral?
    5,667
    Quote Originally Posted by anuraruna@gmail View Post
    If you have a neutral available then you wouldn't need a 415v heater tape
    Apr 2007
    42
    29
    Ordered transformers today. Thanks for the replys
    Jeeez, so many answers I can't get in to say - fair comment, no neutral so no 230v - quite correct.
    I'll just sit in the corner until you've all stopped beating on me
    Aug 2007
    Adelaide Australia
    70
    562
    Sorry Brian we will stop now.
    Paul
    Thanks, I'll take the hard hat off now
  1. Single pole contactor & crankcase heater
    By herefishy in forum Air Conditioning
    Last Post: 01-04-2009, 08:38 AM
  2. crankcase heater thought
    By philjd26 in forum Trouble Shooting
    Last Post: 30-06-2007, 10:46 PM
  3. Crankcase heaters on splits?
    By Makeit go Right in forum Air Conditioning
    Last Post: 12-06-2007, 08:16 PM
  4. Searle Evaporator Heaters
    By Abe in forum Commercial
    Last Post: 31-12-2005, 10:24 AM
  5. Need source for Crankcase Pressure Regulators
    By -=freeze=- in forum Commercial
    Last Post: 16-11-2001, 08:28 PM
