Thread: Cheese room/defrost heaters?
04-08-2007, 03:56 PM #1
I have a customer with a new cheese coldroom. He wants to maintain a temperature of around 12-14c, now what i want to know is has anybody heard of using the defrost heaters and evaporator fans to stop the temperature going too low in the winter?
Cheers Jon
04-08-2007, 04:00 PM #2
Re: Cheese room/defrost heaters?
I have actually seen some cheese storage rooms with gas-fired heaters in them for this purpose. During the winter time, there is no load in the room and the outside air temperature is much lower.
This causes the room to "cool down" below the required temperature, so heating is needed to maintain a cold storage condition.
How's that for a new twist?If all else fails, ask for help.
04-08-2007, 04:34 PM #3
Another guy we look after has an oil filled radiator to keep the temperature up but if he is not careful they end up fighting each other!
04-08-2007, 05:22 PM #4
The radiator is probably a better idea. I'm not too fond of thegas-fired heaters in the space. The vent stacks are an easy means of air infiltration when the outside air temperature increases.
Dampers in the vent stacks are not 100% vapor tight....If all else fails, ask for help.
04-08-2007, 05:56 PM #5
Heaters on the Evaporator Coil (as in defrost heaters), will ussually do the trick, with a good electronic controller. However, watch the humidity as the cheese can dry out too quickly.
Old Refrigeration Technicians never die! They just leak out!
23-10-2007, 09:51 AM #6
Hi, we are supplying refrigeration control system&single controller for freezers
crank case heaters in scroll compressors
By abbasi in forum FundamentalsReplies: 19Last Post: 03-08-2010, 03:04 AM -
Crankcase heaters on splits?
By Makeit go Right in forum Air ConditioningReplies: 9Last Post: 12-06-2007, 08:16 PM -
Cheese Room Evaporator
By Ireland in forum Technical DiscussionsReplies: 4Last Post: 05-04-2006, 11:22 PM -
Cheese Room Design 24V DC
By jbelding in forum FundamentalsReplies: 10Last Post: 02-04-2006, 03:23 PM -
Searle Evaporator Heaters
By Abe in forum CommercialReplies: 14Last Post: 31-12-2005, 10:24 AM
