    Jul 2007
    Kuwait
    7
    air Condition compressor
    Hello all
    what the power in PSI require from air condition compressor for cooling 12000 BTU.???
    Thank you in Advance
    Amsahloul
    Re: air Condition compressor
    Absolutely no idea.
    The question does not have a sensible answer.
    Feb 2007
    2,473
    Amsahloul,
    PSI is a unit for measuring pressure.
    Power is generally measured in Watt, whereas 1000Watt = 1 Kilo Watt.
    12000 BTU ~3.5kW/h
    As a really rough guide you can say that a compressor has a power ratio of 1:2.
    Thus, a compressor with a power input of 1.75kW will give you a cooling capacity of 3.5kW.
    BUT...
    There is much more to the art of selecting a compressor than this.
    You really need to take all your figures, this will include temps, flows and so on, and then look at the data from a compressor manufacturer.
    u.k.
    44
    14
    hello all..could someone direct me to where i can get more information on BTU/kw ratios and how to work out figures for temp,flows etc. many thanks.
  1. Testing Inverters
    By fridge doctor in forum Air Conditioning
    Last Post: 15-06-2011, 06:52 AM
  2. Compressor loading, cooling, and range of operation.
  3. Mitsubishi compressor lock
    By marc5180 in forum Air Conditioning
    Last Post: 08-10-2007, 05:48 PM
  4. Air condition compressor
    By mmtronic in forum Air Conditioning
    Last Post: 28-07-2007, 03:40 PM
  5. Compressor pumping efficiency
    By shogun7 in forum Fundamentals
    Last Post: 25-02-2004, 10:50 PM
