    Feb 2002
    Germany
    13
    pressure drop of pump return line ammonia
    Hey,
    I am searching for a formula to calculate the pressure drop of the pump return line (wet gas recírc. 2-5) of ammonia.
    In practice the pump return line will be mostly one diameter bigger than the gas line but I need to calculate the pressure drop. Because the pipelength are more then 100 m (328 ft) and there is a suction mainvalve. To prevent high pressure drop over 2 K a calculation have to be.
    Could you help?
    O. Möller
    Olav Möller
    Jun 2001
    N.Ireland
    1,630
    Hi Moeller,
    I use the Dircal program available from the Danfoss site for free.http://Danfoss.com
    Search about and you will find this under there Industrial Refrigeration section.
    Any problems locating Dircal, post back and I will go look for the exact link.
    Kind Regards. Andy
    Feb 2002
    Germany
    13
    Hi Andy,
    thanks, this program I use too. But I want to make my own program (Excel sheet to have a better overview of the results and for better documentation). But I do not believe the calculated pressure loss of the Dircalc-program always and I want to know the calculation base. I asked Danfoss, which base formula they take. Up to now I am waiting for answer.
    O. Möller
    Olav Möller
    Jun 2001
    N.Ireland
    1,630
    Hi Moeller,
    in discussions with a danfoss representative, I was informed that there maybe a problem with sum suction lines wet/dry calculated on Dircal below -30 deg C. I might be able to send you a chart on excel to calculate the pipe sizes. I will see if I can make this available to you and I will post back.
    Kind Regards Andy
    Feb 2002
    Germany
    13
    Hi Andy,
    this would be great.
    Thanks.
    O. Möller
    Olav Möller
    38
    Re: pressure drop of pump return line ammonia
    Hi Andy & Moeller, can you post info, Iwould be keen to see spread sheet, as I use Dircal as well.
    regards Magoo
  1. liquid ammonia pump calvitation
    By Kathleen in forum Trouble Shooting
    Last Post: 20-05-2011, 02:18 AM
  2. Measure suction line pressure drop with thermometer
    By Steve Wright in forum Fundamentals
    Last Post: 17-09-2005, 11:05 PM
  3. ammonia refrigeration
    By deepakrbhat in forum Refrigerants
    Last Post: 23-04-2004, 12:07 AM
  4. TEV capacity related to pressure drop
    By DaBit in forum CPU Overclockers
    Last Post: 06-12-2002, 05:11 PM
