    Aug 2007
    ENGLAND
    63
    problems with york yaa c chiller
    hi can anyone help please been out to a york chiller it has 4 scroll comps working as 2 circuits 1and 2 useing common discharge and suction on each circuit, the prob is the unit is only useing a max of 2 comps at any time even if its not acheived temp the control display does not even show any run hours for comps 2 and 3 but in the service mode the system shows the all comps with 0 run time on 2 comps the unit has its eprom changed but no change would be gratefull of any input cheers guys
    ireland
    1,451
    Re: problems with york yaa c chiller
    paul
    you need the service password, check that the model is correct in the program and that the correct number of compressors is programmed. i havn't worked on one in ages so i can't remember the password and i could also be completely off the mark!!
    al
    Aug 2007
    ENGLAND
    63
    hi al have checked all that mate all seems ok thanks for your reply
    Feb 2007
    49
    hi, l haven't worked on one of these for a while so it's a bit sketchy, l know this sounds stupid but are both circuits turned in in the options key?? you said it's had a new eprom if so you may need to re program the chiller and this may be why it says o run hours. l think you press program and then it's a combo of up and down keys pos up up down down up up. try a few examples until you get in oh and press enter. let me know if this helps. neil.
    DjP67's Avatar
    DjP67 Guest
    What is the age of the chiller ?
    Has the board got toggle switches for the compressors ?
    are they switched on ?
    Is the loading sequence correct (as in can it see the other compressos) ?
  1. York Chiller
    By HVACGod in forum Commercial
    Last Post: 11-09-2010, 06:05 AM
  2. York Chiller
    By RubenJLL in forum Trouble Shooting
    Last Post: 18-04-2008, 04:08 PM
  3. York Screw Chiller How low will it go?????
    By bruceboldy in forum Industrial Compressors
    Last Post: 10-08-2007, 10:29 PM
  4. york chiller help please
    By airconadam in forum Air Conditioning
    Last Post: 21-04-2007, 01:31 PM
  5. York process chiller repairs
    By Matt in forum Commercial
    Last Post: 23-03-2004, 11:07 PM
