Thread: fault on a sanyo unit
17-08-2007, 06:34 PM #1
Hi guys, just got a call from a guy at work, who is on call tonight. He got called to a restaurant with 4 indoor sanyo cassettes and one multi out door. The problem is the controller is flashing E04 ( comms error?) problem is im trying to guide him through what to do from here. Iv told him to check the basics i.e power to the outdoor, voltage of the outdoor PCB any blown fuses etc. Are there any sanyo experts around to help as the technical number for sanyo is closed until monday
17-08-2007, 07:08 PM #2
Re: fault on a sanyo unit
does this help
http://www.refrigeration-engineer.co...ighlight=sanyoPaul
"KEEP IT COOL"
17-08-2007, 07:14 PM #3
18-08-2007, 07:44 PM #4
speak to someone at ICG in stockport who supply us with sanyo kit, we have found them always willing to help.
ICG-01614294800
18-08-2007, 07:57 PM #5
thanks Dannycool, but i already have that number and i tried to ring them the other day but they were closed until monday.
18-08-2007, 08:45 PM #6
oh right, well if you pm me your email add, i can send you a pdf of the sanyo service manual, if thats of any use.
18-08-2007, 09:15 PM #7
Hi Marc,
Do you know what system this is ....SAP or SPW?
Guess as you talk about a controller, it is a wired controller so that it will probably be a SPW system (SAP have Infra Red controls). Any chance of a model # ?
E04 is generally Indoor unit is detecting an error signalled from the outdoor unit: Error in receiving serial communications signal.
18-08-2007, 11:04 PM #8
Fault on an Airedale unit
By marc5180 in forum Air ConditioningReplies: 50Last Post: 30-06-2007, 06:10 PM -
Sanyo fault
By casstle in forum Air ConditioningReplies: 1Last Post: 20-06-2007, 11:22 PM -
Sanyo CR 903GY Multi Unit
By bobjob in forum Air ConditioningReplies: 0Last Post: 29-07-2006, 04:27 PM -
Sanyo inverter split unit
By cikku in forum DomesticReplies: 3Last Post: 22-05-2006, 06:07 PM -
MHI, Sanyo & Fuijitsu Complete Fault Codes
By aeb200 in forum Air ConditioningReplies: 1Last Post: 16-11-2005, 01:11 PM
