Results 1 to 39 of 39
Thread: Expansion valves
Threaded View
11-04-2003, 06:24 AM #28
If the TEV is rated for 1 ton Nominal, can it be used for 3/4 to 1 ton systems?
The a/c's I want to experiment with are usually 8500 btu and 9600 btu.
My goal is to have an a/c that puts out a constant evaporator temperature, preferably 35F, but no higher than 40F.
The cap tube system that they currently employ varies in temperature from 40F to 55F.
I even thought of trying R408A to see if I could maintain the desired temperature. I was told that R408A is not as efficient as R22.
What is more efficient than R22?
R502? R407B/C?I visit http://www.fuel-saver.org
Soldering Expansion Valves
By Abe in forum DomesticReplies: 23Last Post: 18-06-2006, 01:07 AM -
VRV expansion devices.
By Markie in forum Air ConditioningReplies: 18Last Post: 14-04-2006, 07:20 AM -
Expansion
By alesindo in forum FundamentalsReplies: 11Last Post: 30-07-2005, 09:16 AM -
Internal V's External Expansion Valves
By Latte in forum FundamentalsReplies: 9Last Post: 25-06-2005, 01:12 PM -
help required in locating expansion valve power head
By Tejbir Singh in forum Trouble ShootingReplies: 10Last Post: 10-12-2004, 02:38 PM
