Thread: CPR question
26-07-2007, 06:37 AM #1
CPR question
While the compressor was running,I turned the CPR valve adjustment all the way counter-clockwise and the pressure did not drop.Shouln't it go to zero?
26-07-2007, 08:23 AM #2
Re: CPR question
No, first of all check on the label what the range of the valve is, the valve is used for throttling back the suction pressure after defrost or start up or to even reduce the load on the compressor to reduce the starting amps, I switch the compressor off so the suction pressure rises before I carry out my adjustments, but check your label first, it may not even be a 0 - 80 psi valve, could be a 20 - 100 in which case the valve will not let it achieve 0 psi.
Heat Transfer Exam Question
By alexdouglas1969 in forum FundamentalsReplies: 10Last Post: 13-12-2008, 04:19 PM -
A question on Heat-Pump.
By lana in forum Technical DiscussionsReplies: 18Last Post: 20-02-2007, 12:15 AM -
Newbie with a question
By AcidSlasher in forum FundamentalsReplies: 4Last Post: 07-03-2006, 11:20 AM -
quizy type question thingy
By rbartlett in forum Chit Chat & Service StoriesReplies: 25Last Post: 06-02-2006, 09:22 PM -
Urgent, Kirchoff question
By Peter_1 in forum FundamentalsReplies: 4Last Post: 20-01-2004, 03:12 PM
