Thread: R134a small chiller
23-01-2003, 03:18 PM #1
R134a small chiller
Gentlemen,
I am working on a small 1/3hp chiller medium temp 134a. Book says charge is absolutely critical that when water temp is stable 52 to 53 degrees the suction should be between 33 and 35 PSIG. Problem is book refering to R-12 not 134a. Using a PT chart I come up with 31 to 33 psig at 52 to 53 degrees water temp. Am I correct? I have done many 12 chillers but not 134a. Thanks!
24-01-2003, 05:15 AM #2
Yes, you're correct as per the charts !
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
Pressure Transmitter R134a Setpoints
By cooltrain in forum Technical SpeculationsReplies: 0Last Post: 28-02-2005, 09:05 AM -
Is there anything about R134a that is better than R12?
By dude in forum RefrigerantsReplies: 5Last Post: 01-03-2004, 09:59 PM -
R-134 Chilling Unit
By enginerous in forum IndustrialReplies: 32Last Post: 25-08-2002, 01:12 PM
