Thread: Too much money
16-05-2007, 01:18 PM #1
Too much money
Iam trying to find a replacement oil filter other than OEM for a sabroe smc 106 recip. It is a screw on just like a car worth about $40.00 US they want $333.00 plus shipping. HELP
16-05-2007, 02:28 PM #2
Re: Too much money
Manufacturers do not supply parts or components to be cheap. Things such as oil filters or replacement parts are where they make their money. However, when they specify a replacement part it is based on what they expect to work and provide a long life.
Obviously, they purchase some parts from the original manufacturers, such as the oil filters. And usually part of their agreement with that manufacturer is to remove all of the original manufacturers visibly identifying marks or details. This helps to prevent someone from going directly to the filter manufacturer to cut out the compressor manufacturers profit.
If you elect to use an alternative oil filter that might happen to look like the original and seems to be the same size, you will not know if the filter media or it's filtering capability is the same as the original.
Substituting parts instead of using the original equipment manufacturers (OEM) recommended replacements places all of the burden on you to ensure the part is equal in performance.If all else fails, ask for help.
16-05-2007, 02:39 PM #3
Re: Too much money
Have you checked with your parts dealer to see if there is an aftermarket replacement? I know on their screws there isnt an aftermarket replacement!!!
They arent cheap either. What I did do was have a set of dual filters installed and eliminated the Sabroe filter. On the Sabroes the filter is in the compressor housing.
16-05-2007, 02:41 PM #4
Re: Too much money
Thanks Iceman, That Is So True. To People That Don't Know About These Things They Just Go By Looks. I Work For A City And The People That Sign The Po's, Look At What It Is And Complain.
16-05-2007, 03:04 PM #5
Re: Too much money
Originally Posted by SIGNSTU
When the cheap parts fail, or in a worse case scenario a major component fails who gets all of the attention then?
Usually the operator for not taking care of the equipment.... A sad state of affairs.If all else fails, ask for help.
Save money / close call
By aawood1 in forum IndustrialReplies: 10Last Post: 18-07-2006, 08:16 PM -
money? money? money?
By xsivhp4 in forum Chit Chat & Service StoriesReplies: 1Last Post: 29-09-2005, 07:25 PM -
Money is Bad for You
By Abe in forum Chit Chat & Service StoriesReplies: 4Last Post: 22-06-2004, 07:13 AM -
Change of Job
By Brian_UK in forum Chit Chat & Service StoriesReplies: 49Last Post: 20-09-2003, 03:26 AM -
Will I never learn???
By Abe in forum Legal-Business-MarketingReplies: 16Last Post: 30-01-2003, 06:39 PM
