Thread: Identify R12?
    craigo's Avatar
    craigo Guest
    Identify R12?
    Please assist me in identifying a refrigerant inside a disposacan. There is no identifiacation on the outside of the can. R134a / R12 / R406a / R409a? Cylinder colour white.
    LRAC's Avatar
    LRAC is offline Veteran Poster I am starting to push the Mods: of RE
    Sep 2006
    Midlands
    453
    Re: Identify R12?
    Quote Originally Posted by craigo View Post
    Put guages on can and measure pressure, take bottle temperature or ambient temp if its been stored long enough in that ambient.
    On a comparitor or guages read off the pressure against the temp and the refrigerant should match at that precise temp/pressure. If it doesn't you've probabaly got a mixed gas cylinder.
    Lrac
    Dec 2005
    Johor
    151
    Re: Identify R12?
    There are always method and means of identifying.
    Refrigerant analyzing tools.
    By means of boiling point.
    Gas identification code mark.
    These are only some method.
    Feb 2001
    Doncaster, England
    199
    Re: Identify R12?
    Pressure/temperature relationship is not accurate enough to identify refrigerants any more. There are too many gases with the same sort of figures.
    Only safe way now is to have it analysed.
    Tony
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    Re: Identify R12?
    Find a freindly auto air con geezer who has something like a Yokogawa Refrigerant analyser, they should be able to tell with reasonable accuracy what you have in there.
    Youd be amazed at just what I found in a Merc Sprinter fridge van with a siezed compressor
    Karl
    Nov 2006
    Australia
    59
    14
    Re: Identify R12?
    Try an old halogas leak detector, a nice green/blue flame will tell you it is R12, if that is what you suspect it to be from the refrigerants in your list. Mind the phosgene!
    Oct 2005
    IRAN
    878
    Re: Identify R12?
    Quote Originally Posted by penair View Post
    Hi there,
    If the refrigerant doesn't have any chlorine in it like R134a then this will not work. If the refrigerant is something like propane (which is unlikely ) then you know what happens with the flame .
    Even Einstein Asked Questions
    Australia
    73
    Re: Identify R12?
    I dont Know about south africa
    But in Australia the only stuff that can be in a Disposable cans is refrigerants that are -30 or lower Boiling Piont
    Gauges/Temp pressure chart still works for me
    & if it is a Hydrocarbon You can smell it
    Aug 2001
    Leominster, MA
    71
    Re: Identify R12?
    Its R12 if its a refrigerant cylinder. You could also use a gauge to verify to a good degree. You'll also need a TP chart and an accurate thermometer. I've always been told that they have a oneway check valve that prevents reverse flow or re-use as an air tank. Did someone drill out the check valve and charge it with air ?Who knows?
    My wife says I don't listen to her....or something like that....
    Apr 2007
    SOUTHAFRICA
    44
    Re: Identify R12?
    hello chomie I would go eather by sending it to a-gas yere in sa for testing'.I do know of a problem ive come across is that there is a recycled r12 which is shipped in from india which can give you headacess so tack it in for testing cheers.
    Apr 2006
    1,620
    Re: Identify R12?
    I just did this last night!
    A refer friend brought me an old cyl of propane he had laying around from when he bought out another chap. I hook it to My BBQ and try and get it going and nothing! So at first I think it is compressed air but no, as there is liquid in there! At this point I am suspicious that it is not propane or air in there but refrigerant!!
    So I take the thermometer and my gauges out, hook on an adaptor I made and take the temp, it was 10C then take the pressure it was dead between 46 & 47, ie it was: 46.5+-.2 and that lands dead on R-12 P&T chart. To confirm I used a torch and got a pretty green flame.
    Using the two methods combined I think you can be fairly certain, it is after the test I noticed the cylinder was much heavier then it should have been with propane further strengthening my hypothesis that it is R-12.
  1. can you identify this
    By Latte in forum Domestic
    Last Post: 12-09-2006, 07:07 AM
