Thread: Line set sizing
06-05-2007, 01:00 AM #1
Line set sizing
Anyone have a book on the proper line set size for a 5Ton AC using R410a?
Thanks!....
My wife says I don't listen to her....or something like that....
06-05-2007, 03:42 AM #2
Re: Line set sizing
What's the size of the fittings?
I'm sure it would be designed for the correct size.
Also check the manuals."If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her coils." - a HVAC friend of mine
06-05-2007, 04:32 PM #3
Re: Line set sizing
You can't always go by the connection size found on the unit or this would eliminate the need for tables altogether. I have tables for R22 but not R410a.
06-05-2007, 09:03 PM #4
Re: Line set sizing
A book about the lines of a 5 ton AC on R410a??
I have a book for a 3 ton and a 7 ton, can this help you any further?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
07-05-2007, 05:59 AM #5
Re: Line set sizing
I can give you the line size if you tell me the followings :
1- Compressor capacity at design conditions.
2- Horizontal Pipe length (suction, liquid).
3- Vertical pipe length (suction, liquid).
4- Number and type of bends.
I have developed a pipe sizing programme and it is easy to size the pipes.
Piping and line sizing in lbs/min
By Kathleen in forum Tools and CalculatorsReplies: 18Last Post: 29-05-2009, 03:07 PM -
Refrigeration Line Sizing
By Capt Steve in forum RefrigerantsReplies: 18Last Post: 26-06-2008, 02:16 PM -
Sizing for Australia
By dogma in forum FundamentalsReplies: 5Last Post: 17-03-2006, 10:05 AM -
Line Sizing and Piping Practice
By subzero*psia in forum CommercialReplies: 1Last Post: 22-06-2001, 03:47 AM
