    Apr 2007
    Detroit area
    66
    8
    help with math problem
    i am trying to find the formula for this problem, I have the wet and dry bulb return temps and the dry bulb unit outlet temp, how do i find the wetbulb outlet temp. I am new to forum, have 30 yrs in powerplant operations, last 18 at Ford motor co. Thought i would try and learn the other side. Thanks Don.
    Oct 2005
    IRAN
    878
    Re: help with math problem
    Hi Don,
    How come you have the outlet dry bulb? Did you measure it?
    Either you have to measure it or you have to do a coil calculation. This means you have to know your evaporator coil's physical info and then simulate the performance of the coil, this will give the outlet dry and wet bulb temperatures.
    If you want to measure it then you can measure the outlet dry bulb temp. and relative humidity. With these you can calculate the wet bulb (with psychometric calculations or software).
    Hope this help.
    Even Einstein Asked Questions
    Feb 2001
    Tampa Florida
    1,076
    i am trying to find the formula for this problem, I have the wet and Dry bulb return temps and the Dry bulb unit outlet temp, how do i find the wetbulb outlet temp. I am new to forum, have 30 yrs in powerplant operations, last 18 at Ford motor co. Thought i would try and learn the other side. Thanks Don.
    The wet bulb outlet temperature is simply a measurement you have to make just like you did with the return air. After that you can caculate your work performed. Oh. There I go, thinking like you are actually measuring these things.
    Is it possible that you are asking how to read tables? Perhaps Lana is more on target with her answer.
    Apr 2007
    Detroit area
    66
    8
    WOW A psychometric calculator, Thats what i needed. Told ya i was a begineer, Thanks.
    Try here for software..
    http://www.linric.com
    Oct 2005
    IRAN
    878
    you can try this :
    http://fridgetech.com/calculators/rel-hum-b.html
    it is free.
