Results 1 to 18 of 18
Threaded View
04-04-2007, 03:26 PM #11
Re: problem in Auto Refrigeration Cascade System
If it is a small system there are few things that are rules of thumb. Try to make the evap down feed so that oil will drain back to the comp. Oil seperators, use more than one. The less oil in the eveaporators the better. Vacuum is your friend, let it run for days. Air and moisture is your enemy. The filter driers should be of the molecular seive type. Got to run Ill post more latter.
Cascade Refrigeration System
By Vincent Yu in forum FundamentalsReplies: 71Last Post: 16-02-2012, 04:04 AM -
Migrate Oil problem - Medium Refrigeration System
By lurioda in forum FundamentalsReplies: 0Last Post: 24-02-2004, 06:20 AM
