Results 1 to 27 of 27
    Jan 2003
    East Anglia
    1,160
    Upside down TEV's
    Hi Guys,
    I seem to remember that a few months ago there was a thread about tev's and whether they would work if located upside down.
    Well i have got to go to a site tommorow with an upside down valve.
    Can anyone point me in the direction of the thread so i can see what the conclusion was
    Fatboy
    Apr 2006
    1,620
    Re: Upside down TEV's
    I would imagin they wotk just fine no matter what way they are facing, I have one running upside down with no problems.
    Jan 2003
    East Anglia
    1,160
    Hi The MG Pony,
    In Theory i know they should work but its one of these jobs that is just a process of elimination.
    I seem to remember someone having problems with one located upside down, poss oil collecting in it.
    Anyway, going to look at the job this morning to see whats going on
    Fatboy
    Apr 2006
    1,620
    oil conducts pressur just as well as gas, so again, it is odd to think it would be a source of problem, Perhaps moisture could build inside?
    Oct 2003
    5,630
    You may install it in any direction, just make that the bulb faces downwards
    Mar 2005
    58
    110
    Normally (99,99 % of the cases) this won't be a problem.
    But everything that may not get into the expansion valve (dirt, small metalic particles, ... ) will get trapped in the valve. If it's a valve with internal pressure equalisation, chances are these particles get on the diaphragm and cause stress ... (causing cracks ....).
    Of course these particles shouldn't go to the expansion valve because you have a filtre drier upstream and most of the TEV have an internal filter, but....
    Mar 2006
    Merate (LC) - Italy
    2,549
    Quote Originally Posted by Peter_1
    Yep, I second that.
    Sep 2006
    las vegas nv.
    66
    will not pose any problem. i see it in bus a/c systems and no problem at all. gravity has nothing to do with the operation of the vavle.
    Canada
    61
    149
    I wish I had read this post yesterday. I spent a lot of time and effort mounting a valve in the upright position, because I believed you could not mount them upside down.
    By the way, after reading this post, I went to my truck, dug through the garbage pail, and found the unread instructions from my valve... and read them. According to Sporlan you can mount their valves in any direction.
    Quote Originally Posted by Sledge View Post
    .......... and found the unread instructions from my valve... and read them. According to Sporlan you can mount their valves in any direction.
    There you go, RTFM
    Aug 2001
    1,046
    If all else fails .... read the instructions.
    If it still doesn't work, do what it says!
    ________
    Honda GB500
    Just spoke with Sporlan yesterday on this topic. Any position OK, just make sure it's not at a low point in the system as it might collect oil making the valve very sluggish.
    Kevin
    5,667
    RTFM
    Com'n then Brian - give us a clue what this TExt speak means
    Mar 2004
    624
    At a guess
    "READ THE F*C*I* MANUAL"
    Bernard
    Oct 2003
    5,630
    The position of the distributor is important, not that of the TEV.
    Thanks Bernard, got it in one ! (Sorry Frank)
    birdman's Avatar
    birdman Guest
    TEVs work on a pressure diff, not on gravity!
    Mar 2006
    Merate (LC) - Italy
    2,549
    Read The F........antastic Manual
    Just a possible reason for NOT fitting them upside down..... corrosion.
    5,667
    Looks more like Gravy to me Brian
    Yep, AHU with three TXVs side by side. They all look a bit crappy. Just condensation causing the problem plus a bit of salt air no doubt.
    Hoping to get the OK to change them at the same time as I change the rusted filter/driers.. Just love working near the seaside
    germany
    5
    Hi guy,
    the pressure is not the problem in this case, as you said it will transmitt it easily. The bottleneck is the temperature!!!!!!!!!!!! The trapped oil does have the temperature of the refrigerant in the liquid line this does influence the bulb and the working bahavior of a TXV.
  23. #23
    Nov 2005
    211
    Would it be a good idea to paint the TXV after installing it? I think there's a zinc-bearing paint just for preventing corrosion (they use zinc to protect the metal parts of boats).
    "If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her coils." - a HVAC friend of mine
  24. #24
    Not a bad idea that, rather obvious now that you mention it
  25. #25
    Dec 2005
    223
    As an OEM case mfr. We prefer to mount them upside down. This way SH can be easily adjusted if need be. Of couse we"re working very clean . I can't say there have been tev problems in fact they're quite the problem free componenant
  26. #26
    Mar 2007
    manchester
    63
    fit any way u like as long as sensing bulb is below halfway on suction
  27. #27
    Apr 2001
    79
    5,071
    35
    Peter_1 brings up an important point in that the bulb should be mounted in the cap tube elevated position. This allows the liquid portion of its charge to be stored in the bulb rather than in the powerhead where it can make the action of the valve sluggish.
  1. idiots stored my new fridge upside down!
    By Milthorp in forum Trouble Shooting
    Last Post: 18-07-2006, 01:49 AM
  2. Problem with three evaporators and TEVs
    By lana in forum Trouble Shooting
    Last Post: 13-01-2006, 09:52 AM
  3. Egelhof Tev's
    By Feargal Loy in forum Supermarket Refrigeration
    Last Post: 27-10-2005, 07:44 PM
  4. upside down fridge/freezer not cooling properly
    By Barney01 in forum Domestic
    Last Post: 07-10-2005, 08:20 AM
  5. Balanced port TEVs
    By Prof Sporlan in forum Fundamentals
    Last Post: 25-02-2002, 03:43 PM
