Thread: chilled water PHE
Threaded View
31-07-2002, 08:25 PM #2
Hi, Priti,
Just I few quick sugestions.
1/Refrigerant charge
2/Expansion valve/level control problem
3/Reduced water flow due to dirt blocking a pump strainer
4/Damaged pumped.
I would try to establish pump flow rates on the Glycol/Brine side. If you have a flow meter on your system this is very simple, otherwise you are depending on commisioning data, such as temps in and out of the chiller and pump Amperes.
Regards. Andy.
Do I need a chilled water buffer vessel
By Consultant in forum CommercialReplies: 32Last Post: 02-03-2011, 09:40 AM -
Chilled Water Coil
By elmusasc in forum FundamentalsReplies: 4Last Post: 11-08-2006, 02:42 PM -
chilled water pump design
By afeef in forum FundamentalsReplies: 5Last Post: 16-09-2005, 12:06 AM -
chilled water storage tank!
By dchatta in forum Technical DiscussionsReplies: 4Last Post: 24-05-2004, 04:23 PM -
Refrigerant vs Chilled Water
By baker in forum Air ConditioningReplies: 4Last Post: 16-01-2004, 02:17 PM
