Results 1 to 50 of 220
Threaded View
31-07-2002, 12:55 AM #11
Actually, a two stage system has two stages in a single compressor. A cascade system is two (or more) systems in series. The high stage system cools the low stage system which cools the medium.
I don't have a P/T chart for propane handy. What low stage pressures do you typically run at -60F? Why do you think mixing it with R134A will help?
Daikin fault codes
What is System balance?
By shogun7 in forum Technical SpeculationsReplies: 56Last Post: 19-01-2006, 09:47 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
