Results 1 to 13 of 13
Thread: direct replace r12
03-11-2006, 08:26 PM #1
direct replace r12
Hello. I have an old vending machine /water chiller.
It is working fine but cooling capacity is a bit low.
I wonder is it possible to refill the compressor whit new
refrigerant ? Compressor is danfoss sc10b and is using
R12 refrigerant. Is there a direct replacement for this ?
My friend has a llicence to change gas but I am not sure
which gas to use. I dont want to scrap the whole thing.
Thanks if you can help me.
03-11-2006, 08:45 PM #2
Re: direct replace r12
It Depends whats available where you are.
normally i would use R409a here in the UK but there other options.
fatboy
03-11-2006, 11:52 PM #3
17-12-2006, 11:38 AM #4
I personally think that R409a is the best Drop in - If your friend has a license to change gas then I am surprised that he didn't know this? If your friend is a gas engineer then he would handle gas in boilers, Gas Ovens etc, and wouldn't have the type of gas used in Refrigeration. Although it may be different in Finland.
18-12-2006, 12:12 AM #5
Used FX 56 (409A) in both hermetic (Unite Hermetique compressor) with an air-cooled condenser, and open systems (York a\c compressor) with a water cooled condenser, both with mineral oils.
My girlfriend in Sweden had her restaurant food freezer system, using a Bitzer open compressor and a water-cooled condenser, changed from R12 to R404A but there has been a very small but persistent oil leak from the shaft seal since then.
Steve
27-12-2006, 12:25 AM #6
Canada has a wonderfull gas called R-414b, good stuff if you can get it. I don't think that its available in the USA, but maybe in Europe?? Beauty Blend.
02-01-2007, 03:30 PM #7
Generally the R-12 systems I have seen converted to R-401a have been fairly low temperature things.
DuPont's web site
http://refrigerants.dupont.com/Suva/.../suvamp66.html
suggests temperatures for that conversion well below freezing.
28-07-2007, 11:07 PM #8
R-414b is known as 'HOT SHOT' here in the US. But I find that R-414a works better than R414b. In fact if you do warranty work for Whirlpool's non 134a systems you are required to use R-414a. this is on Whirlpool household Refig. & Freezers. I also use it in Auto A/C instead of retrofitting to 134a. Plus you only use 80% as compared to R-12.
29-07-2007, 02:36 PM #9
29-07-2007, 03:42 PM #10
We use mainly sp34e here, which is 97% r134a and 3% propane. The propane means a decent mix and return of the mineral oil. This means it's fairly cheap and easy to get.
29-07-2007, 05:37 PM #11
R-414a is sold as Whirlpool's brand name with the 'FSP' . I can get it in 12oz. cans or 25lbs. jugs. I get it at 1st Source parts Servell.
08-03-2009, 02:58 AM #12
U can use R409 gas , without charging compressor oil or Exp Valve but about the pressure .........!!!!!!
08-03-2009, 07:56 AM #13
what about r49 or r413a
