Thread: High back pressure compressors
23-10-2006, 09:33 PM #1
Hi everybody,
Can someone explain the 'High back pressure compressors"? What is the difference and how is the compressor construction?
Cheers.
Even Einstein Asked Questions
23-10-2006, 10:06 PM #2
Re: High back pressure compressors
Hi Lana
high back pressure usually refers to domestic compressors, larger motor for starting.
In screws a different volume ratio is used, and with piston compressors, more valve spring pressure is usually used.
23-10-2006, 10:33 PM #3
Hi Lana...to repeat what Andy said, HBP is normally a term applied to Domestic/small Commercial (Hermetic) compressors.
They are designed to cope with a higher evaporating temperature and are not so dependant upon the cooling effect from the return suction gas.
You can use a HBP compressor in place of a LBP but not the other way round.
If you look at the specifications you will see the HBP is evaporating at about +7 deg C and the LBP is at -25deg C.
Hope this helps...regards Adrian
24-10-2006, 12:14 PM #4
Thanks guys. Very helpful.
I have been away very long. Where is Mark O'Brian?
Cheers.Even Einstein Asked Questions
24-10-2006, 10:59 PM #5
25-10-2006, 05:30 AM #6
25-10-2006, 09:44 AM #7
