Thread: A/c
12-10-2006, 09:45 AM #1
Re: A/c
Hi, Hamud
Check this links posted by Peter_1:
You can do the conversion with a free software program Uconeer
You can find it on http://www.katmarsoftware.com/uconeer.htm#download
Or you can use the spreadsheet of Dan posted on http://www.refrigeration-engineer.co...0617#post50617 post 6.
Also see attached files, this will give you some idea where to start with calculation (sorry it is in IP units but with Uconeer or some other tool you can do conversions
570-825 Load calculation form.pdf
570-878 Load calculation form.pdf
When you have all answers then we can help with calculation and other technical specs.
Hope this will help,
Best regards, Josip
12-10-2006, 12:53 PM #2
Re: A/c
What caind of insulation do you use?
What is with doors?
Which are the climate conditions outdors?
Which temperature and RH you need in room?
What is stored in room and in what quantity?
That is for start.
Renato
