Results 1 to 50 of 102
Thread: Carbon Dioxide Refrigeration
Threaded View
14-09-2006, 10:52 PM #10
Re: Carbon Dioxide Refrigeration
Hi Bruce
AndyP's company use a hot gas generator. Liquid is taken off the R744 condenser, fed to a pump which raises it's pressure to about 10 deg c saturation. The liquid is then boiled oil using waste compressor heat and the subsequent hot gas is used for defrosting the evaporators.
Hope this helps. Kind Regards AndyIf you can't fix it leave it that no one else will:rolleyes:
advanced refrigeration technology
By Lc_shi in forum FundamentalsReplies: 10Last Post: 16-02-2011, 05:22 PM
