    Mar 2005
    Lanzarote
    372
    Mitsi Elec model numbers
    Is there any way to tell what refrigerant Mitsi elec unit is on from the model number? I forgot to write the gas type down on a condensing unit that requires replacing. I think it is R407c but i´m not 100%.
    The model of the condenser is PU-3YJC.UK, serial 90100056 and service reference PU-3YJC.UK. The units was installed 5-6 years ago, so unlikely to be R410a.
    thanks
    paul..
    rbartlett's Avatar
    rbartlett Guest
    Re: Mitsi Elec model numbers
    you sure dem numbers are right
    cheers
    richard
    5,667
    The supplier will be able to tell from the serial number
    Mar 2005
    Lanzarote
    372
    Quote Originally Posted by rbartlett View Post
    No, It should be PU-3YJC
    But I think I may have solved this now anyway. When I went to the local wholesalers they told told me that the model number didn´t exist and they needed more information. Turns out they wrote the number down wrong .
    paul
