    May 2006
    India
    399
    Cascade System Querry
    A cascade system with R-404A refrigerant on high side designed for -35 deg C evaporating and 45 deg C condensing temperature motor tripping on winding temperature thermistor. The suction gas temperature recorded at suction valve is (-18) deg C with the gage pressure of 0.8 bar ; a clear 18 deg C superheat. Could the high suction superheat contribute to tripping thermistor while the envelop is withi limit?
    OR ELSE WHAT COULD CONTRIBUTE TO MOTOR TRIPPING ?
    KORANNE
    Aug 2005
    5,302
    Re: Cascade System Querry
    High return gas temperature can cause the motors to heat up. Loose motor connections can also cause a higher than normal amp draw. Or insufficient motor cooling, i.e., no air flow on motor.
    Jun 2001
    N.Ireland
    1,630
    Quote Originally Posted by D.D.KORANNE
    KORANNE
    Faulty motor, winding problem
    Worn compressor (check discharge temperature)
    Kind Regards Andy
    Oct 2003
    5,630
    We last had a Bitzer (2 years old) which tripped on the internal thermistor (Kriwan).
    Measured the values at standstill and at room temperature and there was a largz deviation from normal.
    So, one of the thermistors is giving a false reading.
    But this can't be repaired, so it runs now only on the overload relay.
  1. Daikin fault codes
  2. Cascade Refrigeration System
    By Vincent Yu in forum Fundamentals
    Last Post: 16-02-2012, 04:04 AM
  3. System Burn Out Troubleshooting
  4. R-23 cascade system
    By S.M.Gokhale in forum Industrial
    Last Post: 08-08-2009, 08:04 AM
  5. problem in Auto Refrigeration Cascade System
    By ernestlin in forum Trouble Shooting
    Last Post: 01-07-2009, 12:41 PM
