Results 1 to 16 of 16
Thread: Gas Driven Recirculation
20-06-2006, 10:18 PM #1
Re: Gas Driven Recirculation
Hi, Terp
Zvijezda(Star) tvornica(Factory) ulja(Oil)
(edible oil please )
Star Oil Factory
Best regards,
Josip
21-06-2006, 11:01 PM #2
22-06-2006, 12:37 AM #3
Hi Josip,
Terp asks a good question. How is refrigeration used to make edible oil? What type of heat exchangers are used and how low of temperature is required?
Thanks,
US Iceman
24-06-2006, 11:19 AM #4
Hi, guys
Originally Posted by Terp
Originally Posted by US iceman
Here are something more about margarine:
http://www.margarine.org/historyofmargarine.html
http://www.newstatesman.com/200003270047
Here you can see more or less complete process.
http://www.naturalandtasty.co.uk/margarine_process.htm
Extrusion machine is pipe in pipe ammonia cooler and depending on amount of added hydrogen before, cooling temperature and time you can produce margarine with diffrent melting points (32-44C or higher) depending on use.
For food we can use only types with melting points from 32C - 36C, otherwise we cannot digest it . To make sweets we use types with higher melting temp due to cooking process under high temperatures around 200C.
Best regards,
Josip
24-06-2006, 05:19 PM #5
Hi Josip,
Thanks for the information. It sounds like scraped surface heat exchangers are being used.
27-06-2006, 11:56 PM #6
Originally Posted by US Iceman
inner pipe is actually a pump pipe. Inside is a rotor with some kind of blades for homogenisation of margarine.
There is another name for those machines used by workers in factory but...I do not remeber that (working there before 10-11years )
Best regards,
Josip
28-06-2006, 09:48 AM #7
Originally Posted by Josip
We fitted two drums on a Grasso 10 plant, just about the time I started with Cross Refrigeration.
I have two spare secondhand plants from the same customer sitting in our yard at work, both perfectly good, but manual control and not compatabile with modern automated production lines
gas driven engine heat pump
By Lc_shi in forum New TechnologiesReplies: 4Last Post: 10-03-2005, 09:25 AM -
LP driven backup refrigeration
By Dan in forum Technical DiscussionsReplies: 1Last Post: 20-04-2002, 09:10 PM
