    Jun 2005
    Stoke on Trent
    588
    Flexi ducting from cassette
    Can anyone point me in the direction of a decent supplier preferbly with an online catalogue to identify components etc for the fitting of flexi ducting, inline fan, grill & back box fed from a cassette, I have a job that I need to to install 2 lots from 2 cassettes. Cheers all.
    Dec 2005
    Cheshire
    264
    Re: Flexi ducting from cassette
    Quote Originally Posted by Andy W
    Andy,
    Flexible duct should only be used for end connections i.e from grilles and 500mm in length max.
    If your fitting a fan then I would recommend the use of solid spiral duct, which would also more than likely need to be insulated if your taking it off a cassette.
    As for a supplier I would try www.cclveloduct.co.uk or www.hargreaves-ductwork.co.uk
    5,667
    Ring Alan @ Trade Ventilation Supplies 0115 979 1684, he'll sort you out with the proper kit
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    Fans and Spares on the Parkhouse Industrial estate?
    Karl
    Oct 2005
    Romania
    44
    66
    "do not follow where the path may lead. go instead where there is no path and leave a trail" R.W.Emerson
    Jun 2005
    Stoke on Trent
    588
    Quote Originally Posted by Karl Hofmann
    Hi Karl, I thought about them, I did not even know they had moved until I went to CEF recently and saw them across the road. When I went to them last some years ago when they were situated in Tunstall I found them to be very expensive and most unhelpful, some one who I know recently purchased a 600mm fan blade from them for a woods fan, it cost £90 + vat trade!
    May 2006
    Altrincham
    9
    SMJ Engineering. Steve Jones. Based in Dukinfield. Really helpfull guy. Will supply or supply and fit. Very familiar with Most Fan Coil types also. Has own delivery driver as well. 07768 513281.
    Oct 2003
    5,630
    Air trade Center
  1. Ceiling cassette enclosures / casings
    By old time fridgy in forum Air Conditioning
    Last Post: 30-03-2011, 12:10 PM
  2. LG Cassette
    By Abe in forum Air Conditioning
    Last Post: 23-11-2005, 10:12 PM
  3. LG Cassette
    Last Post: 01-07-2005, 07:31 AM
  4. LG 10.5 kw cassette timer problem
    By Andy W in forum Air Conditioning
    Last Post: 25-06-2005, 07:09 PM
  5. Ideal Pump for Rosvik Cassette
    By Krups in forum Air Conditioning
    Last Post: 08-03-2005, 08:38 PM
