Results 151 to 200 of 220
Threaded View
28-04-2006, 02:05 PM #11
Re: An A/C system for my computer case... can it be done ?
You're talking about a TEC, or thermoelectric cooler. For the purposes of cooling a pc I wouldn't recommend them. Not only does it take a lot of power (you require a TEC with 50% more power than your processor emits) but you then need a method of cooling the warm side of the TEC that will need to remove 150% of the processor output.
Phase-change refrigeration is much more efficient if low temps are your goal.
Daikin fault codes
What is System balance?
By shogun7 in forum Technical SpeculationsReplies: 56Last Post: 19-01-2006, 09:47 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
