Results 1 to 13 of 13
Thread: Make a Recovery Unit
24-04-2006, 12:29 PM #1
How easy is it to make your own recovery unit and what parts do you need to fit.
24-04-2006, 01:46 PM #2
Re: Make a Recovery Unit
Originally Posted by shark26
Have a holiday in florida and pick up a promax for next to nothing...
http://cgi.ebay.com/Promax-Amprobe-R...QQcmdZViewItem
cheers
Richard
24-04-2006, 03:08 PM #3
Assuming ...you wanted to save $$$. ..Get a new one made from China. Cheaper than you can build.
However, If you wanted to learn ... build /rebuild. get a used one and rebuild. very educational. (hehehe, my buddy, the tightwad, try to build one, already cost him three time more than he could have brought a new one & It look like a piece of ****)Be Happy
24-04-2006, 03:14 PM #4
Maybe something like this , with a bit of copper thrown in.
http://members.optusnet.com.au/hmbrown/VacuumSetUp.htmlThe primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
24-04-2006, 04:32 PM #5
I have done it years ago Pot, Oil Seperator,
Preasure reg valve,Condnser with fan.
But not quite as good as a bought one and looks much more professional than home made, Barrie..
25-04-2006, 02:39 PM #6
Hi guys,
No iam not trying to be cheap. I already have a Javac recovery machine. All i am trying to do is make one with some spare bits i have lying around.
I have a couple of complete small fridge units lying around ( compressor, cond with fan and evap ).
27-04-2006, 07:00 AM #7
Question? Since we got rid of all the ozone depleting *****, we are now using enviormental friendly ***** - non ozone depleting, do we still need to recover *****?
Be Happy
27-04-2006, 10:48 AM #8
Yes you do. HCFCs and any blends containing them still have an ODP. HFCs don't but they have a global warming potential (GWP) measured in the thousands, i.e. thousands of times that of carbon dioxide. Not sure about the US but it is totally illegal not to recover refrigerants here, even topping up a leaking system and so on is wrong.
It's a lovely day to pump some gas
30-04-2006, 07:39 PM #9
Remember releasing refrigerant is basicly murduring us all. ALL WAYS RECOVER!
30-04-2006, 08:51 PM #10
when i first started refrigeration my old boss gave me a home made unit (probably did not trust me with a good unit).it was a simple condensor unit with a reciver.the compresser had a drain plug fitted to check the oil and change when needed.plus hp/lp switches and gauges
30-04-2006, 09:42 PM #11
Ya thats what I figured and designed it around that basis.
21-05-2006, 02:55 AM #12
The USA has the same laws. All refrigerants must be reclaimed.
22-02-2009, 06:49 PM #13
Interesting concept, they ain't cheap to buy eh!
Daikin a/c units.
By rick in forum Air ConditioningReplies: 59Last Post: 18-02-2008, 09:22 PM -
Problem with ducted Daikin
By jutty in forum Trouble ShootingReplies: 8Last Post: 23-07-2007, 05:34 AM -
Seal display unit
By Andy AC in forum Trouble ShootingReplies: 4Last Post: 17-08-2006, 10:45 PM -
M I T S U S H I T A ac unit with no condensing unit
By Chinua in forum Air ConditioningReplies: 2Last Post: 28-07-2006, 06:54 PM
