Results 1 to 14 of 14
Thread: Brazing Procedure Qualification
01-03-2006, 05:24 PM #1
Re: Brazing Procedure Qualification
Originally Posted by frank
Frank is absolutely right. The PED is law in all EU countries, and applies to all pressure equipment within its scope, unless you can demonstrate that is it intended for permanent export to a third country. (i.e. Non EU or EFTA). Not all refrigeration equipment is within the scope of the Directive. You must comply with the PED in the EU, if that is where the equipment is used, by law. However, if your client insists on ASHRAE / ASME in addition, as part of his contract and is prepared to pay for it, that?s a contractual matter between your company and the client. They have no official technical standing as standards outside their country of origin.
The PED is very complex and not easy to understand, so you may consider that the immediate things to ask are:
- Is the prime equipment inside the scope of the PED? Not all equipment is if its components are below category 1 as defined in the Directive.
- What?s in the pipe?
- How big it is? (Because a 25mm tube would be outside the scope of the PED pipe work limits, UNLESS it connects directly to a piece of equipment that is within the scope of the PED).
There is a brazing methodology produced by the British Refrigeration Association (BRA) and the only one that I am aware of in this country that is specific for refrigeration purposes. However good as it is, it is not harmonised to the PED (in other words it is not recognised for compliance with that Directive?s essential requirements) so you can only use it for the type of equipment that falls outside the scope of the PED that I mentioned, referred to as Standard Engineering Practice (SEP).
________
Hermosillo Stamping & AssemblyLast edited by Argus; 07-02-2011 at 08:56 AM.
01-03-2006, 07:58 PM #2
Your comments are very helpful indeed.
For further information the construction site is in West Africa.
The piping is for refrigerant only and we as a company have never been asked to qualify a joint in the past.
All pressure piping at site falls under B31.3 and ASME IX however I cannot see how this applies to HVAC equipment in this instance.
Welderuk
01-03-2006, 09:29 PM #3
Originally Posted by Delboy
Your kit is in a third country so the PED doesn?t apply.
I guess that you will need to obtain a copy of the relevant standards and do what it says if it?s in the contract.
________
BMW R 51/3Last edited by Argus; 07-02-2011 at 08:56 AM.
02-03-2006, 09:35 AM #4
Originally Posted by Argus
What other people are doing is writing a brazing proceedure that complies with ASME IX and testing their brazers by an in house test using this proceedure. That is fine as long as a notifyable body is in place to aduit the proceedure and the tests.
If I was outside the EU I would do the same, bringing in a competent person to assess my proceedures.
Kind Regards. Andy
Brazing vs. soldering
By DaBit in forum FundamentalsReplies: 28Last Post: 19-03-2011, 11:50 AM -
Procedure For Selection Of Capillry Tube
By AMARNATH JHA in forum FundamentalsReplies: 6Last Post: 26-06-2006, 04:57 AM -
Air conditioning maintenance procedure
By Andy T in forum Air ConditioningReplies: 12Last Post: 27-05-2006, 06:57 PM -
Vacuum procedure
By Peter_1 in forum FundamentalsReplies: 18Last Post: 09-07-2005, 08:50 AM
