Results 1 to 37 of 37
Thread: R11
26-09-2005, 12:47 PM #1
R11
Any one still playing with this jooce?
a fridgies life is that of never quite understanding.
26-09-2005, 12:56 PM #2
Re: R11
I suppose there must be a few drums lurking about, but it's totally illegal in Europe.
________
vaporgenieLast edited by Argus; 07-02-2011 at 08:33 AM.
26-09-2005, 01:38 PM #3
Re: R11
Illegal here to . . .
26-09-2005, 02:13 PM #4
Re: R11
Its been banned world wide Im told. It was the best to work with , negative standing pressures, dont leak .
05-10-2005, 04:03 PM #5
Re: R11
Hi, I was just on ship that still has York LTD with R11.
They don't have enough to continue to run so they are asking for a retrofit.
The R123 is a possibility but I heard there is another one available now ??? because R 123 is dangerous (gives cancer) , do you know this new one ???
02-02-2006, 05:14 PM #6
Re: R11
Originally Posted by Greg W
.....you could wash your overalls in it, too.
________
vapolution vaporizerLast edited by Argus; 07-02-2011 at 08:53 AM.
02-02-2006, 05:25 PM #7
Re: R11
Originally Posted by Argus
Wasn't it one of the first refrigerants to be phased-out in Europe in the early 90's
Noah had to leave the dinosaurs behind as they would've sunk the boat.
02-02-2006, 07:00 PM #8
Re: R11
Hi, I believe they still manufacture it in India
02-02-2006, 07:15 PM #9
Re: R11
Originally Posted by Toosh
Quite probably they do.
This is because India is an 'Article 5' country under the terms of the Montreal Protocol.
This allows certain developing countries a per capita allowance of CFCs.
________
BMW E83 historyLast edited by Argus; 07-02-2011 at 08:53 AM.
02-02-2006, 07:18 PM #10
Re: R11
Hi Greg, The negative pressures are bad if you have a leak they suck in air when they are standing still, believe me ive had my share of problems in that area.
02-02-2006, 09:04 PM #11
Re: R11
I have seen a toy bird (basically a heat engine decorated to look like a bird) that uses R11 as the working medium.
02-02-2006, 09:52 PM #12
Re: R11
Use to (many moons ago) have a bucket of R11 next to me when i stripped down compressors.... great for cleaning the sh*t of parts...
:cool: Calvo :cool:
02-02-2006, 10:21 PM #13
Re: R11
Hi. http://www.r22.org/ Found this site very interesting
03-02-2006, 07:43 AM #14
Re: R11
I can't believe it's still available. If we come across an R11 system that has been leaking we must recover any refrigerant and send for disposal. The system MUST then be scrapped or retrofitted.
Thats Australia
05-02-2006, 09:52 PM #15
Re: R11
I recovered some recently. Opened the valve at the bottomof the condenser float chamber and sucked it into some recovery vessels
Easiest refrigerant I have ever worked with
Kind Regards Andy
30-04-2006, 11:06 PM #16
Re: R11
Was good for cleaning out a burnt system
30-04-2006, 11:07 PM #17
Re: R11
01-05-2006, 01:10 AM #18
Re: R11
Hi Greg,
We have still have about 3000Kgs of CFC R-11, Virgin stuff and distilled also at our Sydney warehoure. Also about 1000Kgs of CFC R-12.
10-05-2006, 03:48 AM #19
Re: R11
And to purge the air when the chiller was running there was a valve on top of the condesor to let air/R11 escape. Thats why it is panned.
12-05-2006, 07:25 AM #20
Re: R11
Originally Posted by Graeme Blackman
I am curious what it can be used for in todays time and regulations.
12-05-2006, 02:08 PM #21
Re: R11
Hi, anyone knows where to find R245fa in Europe?
I think this will be the best R11/R123/R141b replacement but im not being able to get it.Guess ill have to still go with R123...
12-05-2006, 02:46 PM #22
Re: R11
You could try BOC... sure there is some round here.
It's a lovely day to pump some gas
28-11-2006, 09:05 AM #23
Re: R11
Teach me to search old posts.
R245fa comes from Honeywell (BOC stock) be warned that the current production is foam grade but they will mix up some nice clean stuff if you ask. We have been on R245fa since 2002 and R11 it aint. Honeywell were working with Ecotez on a flushing system that was an IKK this year.Derek
28-11-2006, 09:06 AM #24
Re: R11
Oh and they also do a flushing grade of R245fa mixed with a stronger solvent.
Derek
03-12-2006, 06:06 PM #25
Re: R11
Negative pressure R11 chillers were a real pig, I had one leak like a cullinder, loose its vac overnight, held 10psi over a weekend, turned out to be flattend O ring on the oil cooler, made sure I change every O ring I ever disturbed on R11 units after that. Its hard to find leaks that leak inwards!
04-12-2006, 09:30 PM #26
Re: R11
Hi.The R11 is still in action.Just been in Singapore for retubing of one chiller .The subcontractors was using it to clean the system.
I do belive they get it from India/China.
I do agree it has been banned in Europe for many years.
Many of the old ships has still the stuff on the plant.The old reefer ships from Russia still have R12 on ther plants.
HGS
06-12-2006, 11:31 AM #27
Re: R11
Suck in air is true. All R11 and 123 chillers ive seen have had purge units attached, These units have counters so you have a Idea it the leak size. If you develope a moderate leak , you can still save 90% of the charge. Try that with a positive pressure refrigerant. Plus I have chemical Info sheets on R123 that state its not as harmfull as lead to belive. Its the doing of a certain company that produce 123 chillers and there properganda to stop others from using there bad ass gas.
09-12-2006, 06:05 PM #28
Re: R11
There are still people around with a stock of R11 but they canīt sell it.
14-12-2006, 02:58 PM #29
Re: R11
Some York OT (LTD compressors) are still alive in North of Italy. Some retrofitted with r123, others with original R11 refr. Customers fill the warehouse of R11 drums in order to have refr to spare.
Air Purger is basic to the good chiller run. In the low pressure side it's difficult to trace a leak. I hate it !
14-12-2006, 03:44 PM #30
Re: R11
hmmmmmmmmm......
I'd be very quiet about that if I were you !
There's no legal way that you can put CFCs into a system any more. It's just as illegal in Italy as it is in any other EU country.
Just because they get away with it doesn't mean that they won't get caught.
22-12-2006, 07:47 AM #31
Re: R11
well, we only note that some of this groups are running, but no one of my organisation put hands on it ! Anyway, there's anyone that can charge and service this chillers (and fill refrigerant on it), but they run and run, and run.....
29-12-2006, 04:45 AM #32
29-12-2006, 04:51 AM #33
Re: R11
What would you do if you had a stockpile of r11 or r12 , sell it illegaly? Personaly I would return it to the supplier for a cash back per kilo. The Manufactories of these world deadly refrigerants should be held responsible for there product.
29-12-2006, 08:25 AM #34
Re: R11
At my workplace we changed out our old R11 refrigerant to R134A and just got rid of 60gal of the stuff that had been sitting on our loading dock for 2 years. Being a government department we pawned our barrels off on another department. Strange thing about government, everyone else has to follow the rules but them......
29-12-2006, 12:59 PM #35
29-12-2006, 05:58 PM #36
Re: R11
no, ours was converted from an R11 to a R134A. I don't know what had to be changed for this to happen as I wasn't involved in the change over. But in the building I am currently in everything gets done because the silver rings say so and no other opinion is taken into account. It's just another reason i'm leaving government.
23-03-2007, 01:42 PM #37
Re: R11
Prevac, Prevent just a couple of stratigies for prevention and removal of non condensables.
