Results 1 to 27 of 27
    Nov 2022
    croatia
    INVESYS ECH 210B PASS help
    Please repairmen, if they have a password to enter the parameters of the purchased second-hand Invensys ECH 210B controller?
    This would replace my defective pictured below. Thanks in advance. Cheers
    Cela remplacerait mon défectueux dans l'image ci-dessous. Merci d'avance. Salutations
    upload pics in a link
    This would replace my faulty one in the image below. Thanks in advance. Cheers
    Please if you have a technical manual for this heat pump.
    Nov 2022
    croatia
    Re: INVESYS ECH 210B PASS help
    Sorry for my bad English, if you can help me I will be very grateful. Greetings
    ireland
    1,453
    Try 22 or 12, it looks a bit like an elliwell.
    Nov 2022
    croatia
    Thank you, but unfortunately it is not, it is an Invensys ECH210B controller.Thanks, but unfortunately it's not, it's an Invensys ECH210B regulator. Do you maybe know where to get it,"ModbusRequestPro" Regards Greetings
    Oct 2009
    77
    243
    It could be 177
    Oct 2003
    5,630
    Or 135 for all Eliwell
    Nov 2022
    croatia
    Thank you, but unfortunately it is not.This is the answer from the Elliwell help desk!Regards Greetings
    Dear sir,
    I am sorry but we do not know the password.
    Passcode has been set by the appliance manufacturer and there is not way to bypass it
    Nov 2022
    croatia
    5,667
    There is a contact link on their web page for this model
    https://brightcac.diytrade.com/sdp/4..._recovery.html
    Or you could just replace the controller with a new Eliwell or similar
    Nov 2022
    croatia
    there is a contact link on their web page for this model
    or you could just replace the controller with a new eliwell or similar
    mozilla_pkix_error_required_tls_feature_missing
    Jul 2017
    croatia
    13
    Did you try pass 77?
    5,667
    Quote Originally Posted by dfranc View Post
    Link Working fine this end
    Nov 2022
    croatia
    https://brightcac.diytrade.com/sdp/435477/4/home/0.html
    I managed to open this, but my pump is missing?
    5,667
    But the contact link is there, so you could email them for help
    Oct 2003
    5,630
    Invensys = ELIWELL
    5,667
    Invensys is now Schneider Electric
    https://www.se.com/ww/en/brands/invensys/invensys.jsp
    Nov 2022
    croatia
    Invensys = ELIWELL
    I didn't understand this.
    Nov 2022
    croatia
    HI
    another Modbus Request Software : Modscan32 or 64
    available here in demo mode (or with license):https://www.win-tech.com/
    a quick demo :https://www.youtube.com/watch?v=STBX1Nc2I0s
    Nov 2022
    croatia
    Could you access the ECH 210B parameters with this keyboard?
    Jul 2017
    croatia
    13
    Yes,but you still need password
    Nov 2022
    croatia
    I tried from 0-255, and it won't open the parameters, there isn't even a -set- mark, and on the old one, when I press both buttons, it first shows -set-, and then it goes on to PAR-CONF, H1, etc.
    Jul 2017
    croatia
    13
    what problem do you have? why do you need to enter to the parameter? change what?
  23. #23
    Nov 2022
    croatia
    This is the second controller, which needs to replace my old one, but it was on another pump, so the parameters need to be changed, which is an impossible mission. It seems that the factory or the former owner turned off the pass and code to enter the config mode. Now I can't learn even with modscan, not even with Dial_ECH2XX_ModBus_1.1.3, and modbusreqestpro, I can't find it. Regards
  24. #24
    Nov 2022
    croatia
    I got Ellivel ECH 210bdt, and with the password 199 I enter the config settings, but I can't learn everything. I should probably use another service password? I don't have access to H5, 6, 7, 8 and many other parameters?
  25. #25
    Nov 2022
    croatia
    I got the instructions here, but I haven't tried it yet. Greetings
    https://chaleurterre.com/forum/viewt...162271#p162271
    private image upload
  26. #26
    Nov 2022
    croatia
    A password will be requested to perform this operation
    On the display, it is shown - - -• Type the password value corresponding to the parameter value Pa H47 ,,,,neeting - - -• Il n'y a pas de possibilité d'entrer un mot de passe,,,,,
    Nothing! There is no possibility to enter a password
    Either the copy card is faulty or it needs to be formatted, but how?
  27. #27
    Nov 2022
    croatia
    Good morning! A new used 9Kw heat pump has arrived, Slovenian version from Technibel.
