Thread: Volume Index
    Jun 2010
    saudi arab
    82
    14
    Volume Index
    Good day
    i want to be cleared the concept of Vi of screw compressors. some compressor have fixed and variable VI.
    And they have calculated figures like 2.6 3.6
    Some typical screw compressor Vi ratings are 2.6, 3.6 and 5.0. A low Vi (2.6) typically is used on booster applications while a high Vi (5.0) is used on high- or single-stage applications.
    this calculation on which parameters reference calculated ?
    Thank you all
    3,363
    Re: Volume Index
    Quote Originally Posted by shaaf View Post
    Good day
    Thank you all
    Shaaf,
    Some information links
    https://nextcomp.ca/wp-content/uploa...er-Digital.pdf
    https://mayekawa.com.au/494/wp-conte...Compressor.pdf
    3,363
    Re: Volume Index
    Shaaf,
    Just to simplify & follow up what you said. Nh3 on Mycom screw in general.
    Vi 5.8 single stage -33/35 deg C
    Vi 2.6 booster -33/-10
    Vi 3.6 booster -40/-10
    Vi 2.6 -10/35
    If machine 2.6 or 3.6 you would not notice much from my experience (Mycom).
    Bigger differential across machine, higher Vi
    Jun 2010
    saudi arab
    82
    14
    Re: Volume Index
    Dear Ranger1
    Thank you so much for your couple of replies. I'm grateful for this.
