Results 1 to 14 of 14
    Aug 2022
    Pakistan
    Grasso Tripping breaker
    I went through problem with one of Grasso compressor its W series with 450Kw motor
    problem is it is causing the breaker to trip when it shifts itself from star to delta.
    Following things checked.
    Motor insulation is okay
    Cable insulation is okay
    Star timing extended and motor working fine
    All things contactors, breakers checked,swapped everything fine.
    When motor decoupled it was working fine (Shifting properly from star to delta)
    Slide calibrations done found normal.
    Can anybody help me on it
    3,364
    Re: Grasso Tripping breaker
    maltaf,
    Some other possibilities could be mechanical.
    To much oil in compressor (overfilled, suction check valve failed.
    To much oil in compressor oil separator
    GEA usually recommend minimum 10 minutes between starts due to oil pump filling up machine.
    Compressor not fully unloaded, check above, recalibrate again.
    If above okay & not already the case, lower compressor package, oil separator etc to suction pressure to help for easier starting, less start up load.
    Sometimes a line exists to do this when compressor off, a line small between discharge & suction cracked open.
    Also check that the breaker is not failing.
    70
    4,702
    47
    Hi it might be worth if you have not already done so. In checking the timer unit that switches over the Star, Delta contacts. If the switch over is not clean then the resultant Load especially from the star contact, can take the breaker out.
    Just a thought. as i have seen this before.
    Cheers Grizzly
    Aug 2022
    Pakistan
    Thanks for your reply
    THERE IS NO OVERFILLING OF OIL.
    OIL IN THE SEPARATOR IS 1/3 OF GLASS
    ADJUSTED DELAY WAS ALREADY 10 MINUTES
    TRIED CALIBRATIONS AND RECHECKED AND FOUND NORMAL
    ONLY THING LEFT IS THE CHECK VALVE
    Aug 2022
    Pakistan
    breaker replaced with other one , it is okay
    Aug 2022
    Pakistan
    but it is working fine when motor decoupled.
    3,364
    maltaf,
    Has this machine been running in the past & now has a problem?
    Or is it new compressor package.
    What is suction & discharge pressures in system & package itself at start up.
    70
    4,702
    47
    Hi All of the above by Ranger are relevant!
    Just a thought have you put a Clamp meter on the incoming supply to see what the Comp is pulling Amperage wise?
    Star Delta timers are normally around 7 seconds duration. Just as a question which Breaker is Tripping?
    What is your oil temp by the way on start-up?
    Good luck Grizzly
    3,364
    Maximum oil pressure 350 kpa above discharge pressure at all times, otherwise damage may occur mechanically.
    If compressor not connected, of course no problem, as no load on start up.
    Calibration of slide valve always best when compressor running.
    So could still be an issue.
    Aug 2022
    Pakistan
    maltaf,
    it was running earlier.
    suction pressure 2.25 bar discharge 12.0 bar
    Aug 2022
    Pakistan
    Good luck Grizzly
    main breaker. If we extend the timing breaker from substation goes trip.
    oil temp 36C
    Sep 2005
    42
    191
    check the amp draw while it's starting up in star before it switches to delta?
    70
    4,702
    47
    Great minds think alike?
    That's exactly what i was trying to imply. You can get a huge inrush between switching contacts.
    Not sure what is meant by this? 10secs as previously mentioned is already on the long side.
