    Jul 2012
    Australia
    61
    12
    rotary compressor efficiency test
    Hello, can any one tell me if its possible to do a normal compressor efficiency test on a rotary compressor ie run with closed suction to check pumping performance. System is a hot water heat pump approx ten years old, havent had much to do with these things but suction seems a bit high and it runs longer than i would have expected.
    Anyone help appreciated
    Its a rheem system if that helps
    70
    4,703
    47
    Re: rotary compressor efficiency test
    Hi RBM
    Which rheem system / Unit is it Only i have some rheem info.
    70
    4,703
    47
    I forgot to ask what makes you suspect the comp Dis. Valves?
    Cheers grizzly
    Jul 2012
    Australia
    61
    12
    Cheers grizzly
    Thanks for getting back, havent had much to do with these but suc pressure seems high (15 degrees 56 psi r134a) and seems to run for a long time. Its about ten years old and wondered if compressor worn as they must do big hours and must also run a decent head pressure as water temp is plus sixty degrees. Also air on evap to air off is only 4-5 degrees
    Rheem Model no is 55132507/05
