Thread: Evaporator Orientation
28-11-2020, 10:13 AM #1
Does an evaporator have to be mounted vertically?
con1.jpgLast edited by Wickfut; 28-11-2020 at 10:21 AM. Reason: added photo
28-11-2020, 11:50 AM #2
- Sep 2009
- Iran
- 66
- 674
- 1
- 19
Re: Evaporator Orientation
Gas flow in DX SYSTEM ( frion or NH3) through
Evaporators are Horizontal.
But in wet and flooded system is Vertically gas flow from bottom to top
In DX system with one line pipe you use it in vertical inlet gas from top with U in the end of evaporator.Last edited by mbc; 28-11-2020 at 11:59 AM.
28-11-2020, 12:02 PM #3
So, in a traditional refrigeration circuit using r134a, it's ok?
28-11-2020, 02:28 PM #4
- Sep 2009
- Iran
- 66
- 674
- 1
- 19
Yes
But your system should be clean and also with R134A you should use synthetic oil with right grade depending on your temperature
25-01-2021, 09:39 AM #5
