    Northants
    290
    Nice Ice icemaker fault light flashing slow
    I have a nice ice model N52L icemaker with the red fault light flashing, the manual says it's the condenser temperature sensor failed / not connected, i measured the resistance of the sensor and it was about 6kohms at 13 deg C, the bin sensor was the same, so i swapped them over and still have the same fault.
    any ideas on what could be wrong or where i can get technical help / spares from would be helpful
    CB
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Nice Ice icemaker fault light flashing slow
    Chinese s***t.
    Doubt If you can get spares, try the UK importer.
    Dec 2006
    105
    It's the same as a polar from Nisbets; you should be able to get support and spares via them or Uropa Distribution
    My guess is the PCB is faulty, or the probe socket is an issue if the probes are fine. However, if it is anything other than the probe, then it probably isn't worth it - these retail at £250, and are about as rubbish as you can get.
