    Sep 2005
    uk
    5
    Fan speed controller set up
    How do you set up a new controller, with adjustable
    electronic control.
    Re: Fan speed controller set up
    Quote Originally Posted by Ianh
    electronic control.
    If it's a new controller then read the instruction manual.
    Oct 2004
    Scotland
    1,454
    electronic control.
    You adjust the setting to either speed up or slow down the fan.
    Chillin
    and go get a cuppa
    Dec 2005
    225
    You might try taking amp readings then do the math.Ken
    Newcastle, United Kingdom
    30
    Normaly theres fitted speed regulator controller on it try to read the manufacturer's manual carefully.
    rudi
    mustardseed:) :) :)
    Aug 2005
    Australia
    42
    44
    Guys,
    With an adjustable fan speed control, what would be the correct condensing temp to set a fan speed control to regulate the temp to?????
    Oct 2003
    5,630
    How I do it what won't say this is the correct procedure: I take the estimated HP in summer (10 K above 30°C outside temperature ) and regulate then that the fans are running full speed.
    Eventually blind the consensor so that pressure can rise.
    Minimum speed is a speed that the fan is still running and can start up alone after a complete standstill (fan must be able to overwin it's bearing friction)
    5,667
    Hi Peter
    Most electronic fan speed controllers have a hard start built in so no need for worrying about minimum setting and starting.
    The fan normally starts at full speed for a set period and then control takes over.
  1. Help with new electronic refrigerator controller !
    By EngiGal in forum New Technologies
    Last Post: 08-04-2006, 07:39 PM
  2. Controller wiring
    By Mickvee in forum Air Conditioning
    Last Post: 30-12-2005, 02:04 AM
  3. Fan Speed Controller
    By Abe in forum Commercial
    Last Post: 02-06-2004, 05:46 PM
  4. liebert internal fan speed controller
    By rbartlett in forum Air Conditioning
    Last Post: 22-10-2003, 08:51 AM
  5. Fan Controller
    By Abe in forum Trouble Shooting
    Last Post: 12-01-2002, 02:21 AM
