    Scotland
    327
    Charging system using recovery machine
    Hi There
    Can anyone give me a good reason why it would be a bad idea to use a recovery machine to charge a system with refrigerant, apart from the possibility of oil contamination?
    Contactor
    Apr 2008
    Southampton, England
    49
    1,023
    Re: Charging system using recovery machine
    I can't. Since the price of refrigerant has gone through the roof that's the way I do it now to get the dregs in.
    Feb 2009
    telford
    2,090
    33
    I have done it on some car aircon when I could not locate the suction port only a delivery port
    May 2012
    59
    1,528
    The machine does not know which way it is pushing so if the
    machine can do either direction I see no reason why not.
    I always advise people to push it in with a recovery machine
    especially if you have a lot to do and it is cold, the days of
    trying to warm a cylinder to get enough pressure to charge the system are long gone.
    Rob
    Dec 2008
    563
    Suggest that you use a liquid line filter to make sure no impurities get into the system. Otherwise as has been mentioned, it is the best way to recharge a system, especially if you have a lot of gas to put back in.
    May 2012
    59
    1,528
    Quote Originally Posted by hyperion View Post
    Good point and I'd offer you some Luuuuvvve if I didn't have to spread it around
    Rob
