    Feb 2009
    telford
    2,090
    33
    Thumbs down Eco triple fan freezer evaporator fan wiring
    Worked on one of these evaporators today one of the fans had siezed ,replaced the fan motor and it did not run although the other two did checked for power no voltage traced it to what i can only call a stupid connection block located behind the fan,so one cable comes out of the junction box then hidden in the path to motors is this connection block yes its oem,I have seen some crazy ways to wire stuff but this is out of the idiots manual.
    ireland
    1,451
    Re: Eco triple fan freezer evaporator fan wiring
    Yep, absolute balls of an evaporator, fitted one, never again!
    Sep 2003
    ISRAEL
    72
    4,248
    What fan make and model?
    EBM has wierd connections.
    Feb 2009
    telford
    2,090
    33
    No problem with the fan,it was they way eco wire the supply they should have wired each motor to the junction box instead of one feed out of the box and crazy junctions enroute to the motors,ok it saves about .5 of a metre of cable but mental
