11-02-2018, 04:47 PM #1
Ciat "Aqua Ciat LDC with a Connect Controller
Hi Guys
Can anyone advise.
I have one of the above locked out on Fan Fault.
However when the fan contactors (2) are pushed in either fan runs.
I have pressed the reset, but the fan fault remains.
Help.
11-02-2018, 06:05 PM #2
Re: Ciat "Aqua Ciat LDC with a Connect Controller
Do you need to reset it on the controller !
11-02-2018, 06:18 PM #3
According yo the manual it should reset automatically when the input is closed. (??)
Page 53 of manual...
https://www.google.co.uk/url?sa=t&so...n47hh1xG_7fdjeBrian - Newton Abbot, Devon, UK
11-02-2018, 06:49 PM #4
Yes and yes Guys!
I tried pressing the reset But the fault did not clear!
I read the same Brian. As to what the input refers to I do not know?
I am assuming it needs to be reset within the software somehow?
But so far I am at a loss.
Cheers GrizzlyDespite the High Cost of Living it still remains Popular!
11-02-2018, 06:55 PM #5
I also tried the "Three Pin Reboot" that did not work either.
11-02-2018, 07:04 PM #6
You must need one of those "big effing hammers".
11-02-2018, 07:26 PM #7
Hi Brian.
No a resurrection Kit its on a hospital site.Despite the High Cost of Living it still remains Popular!
11-02-2018, 10:35 PM #8
Hi Grizzly.
It's possible that the fans are linked together via a fan internal thermostat connection across all fans all of which needs to make before any fans will run. Just a thought.
12-02-2018, 08:09 AM #9
12-02-2018, 04:19 PM #10
good points RB.
I am back tomorrow to try and identify what's happening.
Has anyone had similar?
12-02-2018, 05:36 PM #11
I've had what Gibbo says but. Not on a ciat good luck
