Thread: jvac connection to hose set
13-12-2017, 11:13 PM #1
Hope someone can help with what should be something very simple. I cannot get an adaptor to fit R410A hoses to my jvac pump. Pump has 3 connections with caps. One 1/2 acme one 1/4 and one what I think is 3/8 or 5/16th ?
I bought a 5/16 to 1/4 adaptor which fits the 5/16th (or 3/8) but unfortunately gives me 1/4 male again so no better off. I seem to need female 1/4 to male 5/16th. Hoses are correct as they fit service valve on a R410a split. Help appreciated
13-12-2017, 11:43 PM #2
Re: jvac connection to hose set
R410a hoses normally have different size connectors at each end, one for your manifold and one for the 410 access port.
Your vacuum line should just be from the pump to the manifold.Brian - Newton Abbot, Devon, UK
By reading your post. I am kind of left with the feeling that you shouldn't be working with this...
-Cheers-
Tycho
14-12-2017, 02:38 AM #4
My thoughts entirely,maybe it's me with vast experience of having to adapt but out in the field not with this particular problem is making bottle adaptors from sealing caps metal of course,being faced with a 3/8th fitting on a receiver tank and cobbling a two nuts one 3/8th and one 1/4 and a piece of 1/4 tube big flare for the 3/8th hey presto a reducer is born but hey I am old school and not a defeatist.
-Cheers-
Tycho
14-12-2017, 04:18 AM #6
Hi Cider.
Welcome to the forum.
One thing that can really compromise working with R410a is the style of Manifold you have.
If you have a 3 port Manifold which I suspect you may have.
Then you are going to struggle!
Because all 3 ports are !/4".
If however you have a 5 port manifold then the vacuum port is already a 3/8 fitting.
Which is a dedicated "Vacuum !" Port.
I am a little confused as to what hoses you actually have, only as has already been said the Industry standard 410 hose as the 5/16"F one end and a 1/4"F the other.
The fittings on your pump are standard.
Alternatively if you wish to connect remotely of a Manifold.
Which is what I suspect you may well be asking?
You may have to buy a short 3/8" hose and a 1/4" female to 3/8" male fitting.
Which will enable you to connect to the 3/8" fitting on the vacuum pump direct.
I am not sure that you can connect an adaptor direct onto the 5/16" Fitting? (For good reason)
The whole thing rests around the fact that you seem to be describing your hoses as 5/16 both ends?
Or am I mistaken?
Good Luck in your quest!
GrizzlyLast edited by Grizzly; 14-12-2017 at 04:56 AM.
15-12-2017, 04:25 PM #7
Thanks for the replies. I have figured it. My hoses and 3 port manifold are indeed ALL 5/16th being 410a. I realised i have an adaptor on my nitrogen regulator which is a 1/4 socket and a 1/4 by 5/16th nipple which is what i needed. 5/16th female to 1/4 adaptors are 2 a penny as hoses are i guess usually 1/4 but going the other way is no so common. Thats what you get for buying cheap crap i guess.
