Thread: Water vapour app for android
I had an app for calculating the water vapor temp/pressure made.
it's nice to have handy when vacuuming large systems to figure out if you are pulling against moisture or a leak
I had a small laminated table that I used, but I kept misplacing and loosing it, so I had a guy make an easy app for me
it's not 100% scientific, but close enough for what I need it to do.
if you want you can download the app here
https://drive.google.com/open?id=0B3...XZmVndCUm9KMGs
you also have to allow your phone to install an app that is not from google store.
(it should prompt you when you try to install, so just press "allow for this app only")
hope you like it
-Cheers-
Tycho
15-06-2017, 07:13 PM #2
Re: Water vapour app for android
Very handy, thanks.
15-06-2017, 07:35 PM #3
Tycho,
very useful, thank you.
Josef.
Glad you like it
if you have any ideas for other apps that would be nice to have, I have a programmer on hand that can make it happen, as long as it isn't too advanced-Cheers-
Tycho
