Results 1 to 29 of 29
Threaded View
25-04-2017, 07:41 AM #3
Re: This should be easy for you experts.....
Hi, thanks for the reply, yes I did test for power at all the fuses I could see (on both sides) , they're ok and did try the controller too. Have had the engine running. Do continue to state the obvious though because it must be something that simple I hope. That's why I wondered if there was a reset button or similar.
Thanks again
