    May 2012
    1,528
    HFO Refrigerants
    HFO refrigerants are unsaturated HFC refrigerants and
    recognised as the next generation of refrigerants because
    of their environmental friendliness.
    I’m not a chemist and I don’t fully understand how the
    process works but if HFO’s are unsaturated HFC’s, what
    are HFC’s saturated with?
    Rob
    3,853
    Re: HFO Refrigerants
    Afaik they just changed the nomenclature so as to distance the new refrigerant from the hfc phase out.
    Mar 2010
    Lisbon
    55
    Well, I am not a chemical myself but the question is really chemical.
    The carbon atoms can each be connected with 4 hydrogen or fluor or other carbon atoms and the various combinations gives the different HFC with the different characteristics we know:
    If in two of the carbon atoms we only "occupy" two connections with hydrogen or fluor, the other two will be linked with another carbon atom being "unsaturated".
    These connections are "weak" and can easily be destroyed, for instance if there is a leak and the gas goes to the atmosphere and receives the sunlight (ultraviolet). In this situation the resulting substances will have a lower global warming potential and so it's a kind of "biodegradable".
    That's why they are said to have a lower GWP.
    5,667
    can't give you any points mate....I must share them around first
    May 2012
    1,528
    Quote Originally Posted by cduque View Post
    Absolutely fantastic. Brilliant answer and I actually understood it.
    I can't give you any points either so my eternal
    love on Valentines day will have to suffice.
    Rob
    Nov 2006
    708
    That is a good explanation
