    3,365
    screw compressor & motor bases should they be machined?
    Question about compressor & motor feet, should their mounting pads on base be machined, or as long as they are reasonably flat.
    This would be a direct drive application with open drive coupling, no bell housing.
    What would be a minimum acceptable standard, remembering alignment has to be carried out to a high standard.
    Aug 2007
    Adelaide Australia
    70
    562
    Re: screw compressor & motor bases should they be machined?
    Hi Ranger
    We always get the bases machined it saves a lot of time when aligning.
    We have done this for many years now, adds to the cost a bit but saved on commissioning time for line up.
    We use the tolerance in the laser aligner which is pretty tight.
    Old standard was 0.001" / 1" coupling diameter for both facial and radial.
    Paul
    Born to fish, forced to work
    Jul 2006
    865
    I have done hundreds of alignments without laser equipment. Field and production environments both. the only place I have seen bases ground is in a shipyard.
    Of course if the bases are not well constructed, issues like soft foot can be a problem.
    the .001 to .002 TIR standard I always used is more than close enough. Remember these are called flexible couplings for a reason.
    I have no experience with the laser equipment, but am not against it. It may be faster and require less experience, but in reality is not going to give better results.
    Also remember that your careful alignment can change quickly due to temperature, even if you do a hot check.
    3,365
    Have seen a package from a major screw compressor manufacturer without machined feet.
    Of course with some difficulty aligned it as motor feet were only touching on four points, not full contact.
    Seems pretty ordinary to save a few $.
    What next?
    Jul 2006
    865
    It has been a long time since I installed a screw package.
    The last was an FES. It came with Shimless Motor Mounts.
    Problem solved. No soft foot or other issues.
    Fully adjustable-no shimming needed.
    3,365
    Quote Originally Posted by NH3LVR View Post
    Yes have worked with them & good to work with.
    If purpose built with them only way to go.
    Apr 2009
    home
    32
    These are a God send.. Almost criminal on how easy this makes alignment procedures.
    38
    open drives on a horizontal oil separator are a right pain in the butt, machined pads or not. Cold alignment then check hot alignment and average final set up, never perfect.
