Thread: press or temp.?
    Nov 2001
    wi,usa
    27
    press or temp.?
    we were having a discussion this morning in the shop about how all the guy like to control box temp. in walk ins and reach ins. either using pressure or return air temp. what do you guys like and why?
    Jun 2001
    Chicago Il
    52
    98
    AAron, For walk in coolers(med temp) I prefer the use of the digital penn johnson controller. You can program the cut in and cut out temps, specify a specfic differential, and also a time guard. These stats utilize a electronic resistance silver bullet sensor and can be remotely mounted from the stat itself. These types also control frost very well on med temp coolers.
    As far as freezers go it really dosent matter. They run 22 hrs a day, and defrost usually 4 times a day. I always stay away from
    pressure type controllers as they are touchy setting up and take forever to confirm satisfactory control.
  1. MP66 & Compressor Overheating
    By Intermez in forum Technical Discussions
    Last Post: 13-04-2010, 08:58 PM
  2. Replies: 3
    Last Post: 06-11-2006, 05:04 AM
  3. lowering freezer temp ?
    By knighty in forum Industrial
    Last Post: 18-08-2006, 06:24 PM
  4. Condensing temp in refrigeration
    By anup in forum Fundamentals
    Last Post: 02-10-2005, 11:18 AM
  5. Multiplex For Low Temp and Medium Temp
    By allanbaker in forum Technical Discussions
    Last Post: 28-11-2002, 10:15 AM
