    Sep 2003
    ISRAEL
    72
    4,248
    R1134a refrigerant pump
    I got a nice contract to fill once a month 10 bottles of 60kg each from a ton container.
    Looking for a dedicated pump for the job.
    Anyone who knows something, heard something or seen something that can help, your input is valuable [my bank manager is with me on this one...]
    3,853
    Re: R1134a refrigerant pump
    Sep 2003
    ISRAEL
    72
    4,248
    Thanks,
    Sent them a request.
    ireland
    1,451
    If it is liquid would an appion or similar recovery unit work, would the virgin gas kill it i wonder?
    Sep 2003
    ISRAEL
    72
    4,248
    Quote Originally Posted by al View Post
    I start tomorrow with my recovery unit. I don't see any problems apart from the fact that it will take more time than a pump [they pay per hour....]
    May 2012
    59
    1,528
    Can you push - pull with your recovery?
    Are you putting 10 x 60kg into the ton pig or are you
    taking the 10 x 60kg from the pig/
    Rob
    May 2012
    59
    1,528
    Just re-read your original post, "from the 1 ton pig"
    Could you not build a 10 way manifold from pipe and then
    vac out the cylinders, plus freeze the cylinders and use the
    pressure difference to move the refrigerant?
    Rob
    Sep 2003
    ISRAEL
    72
    4,248
    Rob
    Busy day at the pub Rob?
    The bottles are being filled on electronic scale, ambient is 30, North pole is 12000 km away, where am I going to freeze them?
